Lister Dating
+14
interloper
toaster
ED3229
Peter D Owen
ou enjin
Peter
lister
Jezmiester
18 posters
Lister Dating Empty Lister Dating
Post by Admin Wed Jul 22 2009, 17:28
If anyone would like to try and find out some history, and dates on a lister they have the man you need to email is David Edgington email him on this link mailto:info@stationaryenginebooks.co.uk he is very helpfull bounce
Lister Dating Empty Re: Lister Dating
Post by Statman Wed Jul 22 2009, 17:45
Ive tried to email him using this email and it didnt seem to reply back!
Also i will try to find David Edgintons Home Address
Post by Admin Wed Jul 22 2009, 17:46
leave it with me ill see if i can dig up more possible leads
Post by Guest Fri Jul 24 2009, 15:13
If you check this site out it gives you some engine dating information for Listers:-
Happy cranking, Very Happy
Stu
Post by Admin Sun Jul 26 2009, 17:12
Stu's site is very good, if that fails ive been digging and the best way to get hold of David is by post, if you post him engine details you will have a signed letter back from either him or his wife address to follow
Post by Guest Sun Aug 09 2009, 21:09
Ryan did you manage to Find David's address? If so can you pass it on to me as I'd like to see what information he can give me on my Lister J.
Post by Admin Tue Aug 11 2009, 06:00
no now im online again i will try but did hear through the grapevine he is responding to emails again, leave it with me
Post by Guest Tue Aug 11 2009, 15:15
I have tried emailing him, just last week so maybe to soon for a reply. So I'll let you know if I get a reply or not.
Post by Jezmiester Mon Aug 17 2009, 23:19
I emailed this address and another about three weeks ago and had no responce so i would go for snail mail.
His Address is
Lodge Wood Farm
Hawkeridge
Westbury
Wiltshire
BA13 4LA
Good Luck All
Jez
Jezmiester
Post by Guest Mon Aug 17 2009, 23:55
Thanks Jez, I've tried to email him with no success, so now I'll try a letter. I'll keep you posted if I get a reply.
Lister Dating Empty Brilliant i sent a 2nd email this week
Post by Admin Tue Aug 18 2009, 04:10
to another email address but no joy, ill also post this address in the suppliers section, thank cheers you jez
Lister Dating Empty David Eddington's Lister Dating
Post by Admin Tue Aug 18 2009, 04:20
Write a letter with your serial numbers and engine details and you should get a letter back with the year your engine was made and maybe some history
David Eddington,
Lodge Wood Farm
Hawkeridge
Westbury
Wiltshire
BA13 4LA
Post by Guest Thu Aug 20 2009, 21:04
Thanks for your help Ryan, letter has now been posted. Very Happy I'll keep you informed of the results.
Post by Guest Tue Aug 25 2009, 15:28
Just to keep you up to date I wrote a letter to David to get the date etc for my engine. I posted the letter on Saturday and the reply came back today Tuesday, can't get much faster then that, so this is the best option to contact him.
So my Lister J type was built 12/12/1926 and supplied to a company about 3 miles from where David lives. Company name was Reeves of Bratton, Wilts anyone know anything about this company?
Post by JONESEY Tue Aug 25 2009, 22:05
Stu I think they were a building firm, they made there own beams and stuff.
Not sure weather there still going they were when I was a Lad.
Wiltshire born only Emergrated to Dorset 2 years ago lol!
Post by Guest Wed Aug 26 2009, 14:49
Chris, All that David's letter said was Reeves Of Bratton were in business until sometime in the 1960's and took many Lister engines. Nothing to indicate the business they were in or what the engines were used for.
Lister Dating Empty LISTER D POST 1945 ENGINES AND DATING......
Post by mike d Sat Oct 24 2009, 12:06
if your engine number begins with 1/ or has a number with less than five figures, it was built after 11/3/1946.
because at that time engine numbers had reached 199999 and the decision was made to introduce a shorter numbering scheme starting with 1/1000. this system continued until DECEMBER 1951 by which time engine numbers had reached 1/77820.
At this juncture a further change was introduced because from 1952 onwards every engine number began with 1 at the start of each year and to avoid any confusion the SPEC.number was arranged to give the year of manufacture of each engine.
So for example DH2 was manufactured in 1952,DH3 in 1953, DH4 in 1954, DH10 in 1960 etc. hence an engine bearing the following number-281 DH5 was manufactured in 1955.
The majority of engines built from JUNE 1948 onwards were built at WROUGHTON,near SWINDON, production continued until about 1964.
Fortunately a little more information has been made available and enables the previously produced dating guide to be extended to 1958.
a final point concerning the reading of SPEC numbers on the later engines.
Instead of DH3..you might see DR3 or DZ3, so to avoid any confusion this small list may help our forum members in the future
SPEC...DR= R means radiator cooling.....
SPEC...DZ= Z indicates REVERSE rotation..however to add to the confusion..R was often used on earlier engines...
SPEC...DK= the K Stands for kerosene......
SPEC...DH= H..of course meaning hopper cooled......
SPEC...D2= sometimes used to determine output...IE..2hp.....
If your SPEC plate is missing from your engine you should be able to find the number stamped on the flywheel crown......
hope this helps some of our members....
mike d....
Lister Dating Empty Can anyone date this lister D
Post by Admin Sun Nov 01 2009, 17:19
en number 3753, (think it may be a later model), DH7 1.5HP 700rpm. Thankyou,
Post by lister Sun Nov 01 2009, 20:48
dh7 means it was built in 1957
lister
lister
Lister Dating Empty thankyou for the info
Post by Admin Sun Nov 01 2009, 20:49
i thought it was a later one, cheers cheers
Lister Dating Empty Lister engine history and dating
Post by Peter Sun Apr 04 2010, 07:24
ryan wrote:If anyone would like to try and find out some history, and dates on a lister they have the man you need to email is David Edgington email him on this link mailto:info@stationaryenginebooks.co.uk he is very helpfull bounce
I have recently purchased a Lister D type petrol engine, 2 HP, 1000 RPM, S/N 2814.
Would you be able to provide information on the approximate year of manufacture?
Thanks in anticipation
Peter
Email [You must be registered and logged in to see this link.]
Peter
Post by ou enjin Thu Apr 08 2010, 19:14
ect....
Do you also have the spec number of this engine? I think it is one of the last years.
Let us know everything that is on the brass plate.
ou enjin
ou enjin
I really need to post more
Lister Dating Empty Lister D2 date of manufacture (cont)
Post by Peter Sat Apr 10 2010, 06:36
The brass plate has on it:
No 2814D2
Spec (blank)
HP 2 RPM 1000
Peter
Post by ou enjin Sat Apr 10 2010, 09:08
2814D2 is your serial number and spec number combined.
It is serial nr. 2814 and spec D2, and is built somewhere in the beginning of 1952.
ou enjin
ou enjin
Lister Dating Empty Lister dating
Post by Peter Tue Apr 13 2010, 11:21
Thanks for the information
Peter
