Villiers WX11 exhausts
Hello,
Just be reading the Villiers WX11 Manual and noticed something intresting, the reason I found it intresting is you see alot of villiers fitted with them, and thats up right exhaust, says in the manual that the exhaust outlet from the base should never be in a vertical position, now it says it will restrict power, which isnt a problem for shows, but just thought it was intresting as you see so many with them.
A copy of the manual page is attached, its under general.
Re: Villiers WX11 exhausts
I think they should ban the smokey things
Very true, my Sandwich smokes well I do beleve
Not that I seen, ran lovely up semington
https://www.youtube.com/watch?v=UylCX159XPs
I like the way it just effortlessly trips the ignitor and fires!
JONESEY wrote:Very true, my Sandwich smokes well I do believe
CHRIS....
you need to cut it back to 5 a day....
it will thank you for it
regards......mike....
» villiers wx11
» Villiers WX11
» villiers wx11
» Villiers wx11
» Help : Villiers WX11, how do you set the points ?
» Villiers WX11
» villiers wx11
» Villiers wx11
