HELP PLEASE ROPESTART PULLEY REMOVAL FROM JAP 4-6
HI I CANT SEE A WAY OF REMOVING THE ROPE START PULLEY FROM MY
JAP 4/3 TYPE ENGINE
ITS AN ALL ALLOY PULLEY SO ASK FIRST AND TRY NOT TO BREAK LATER lol
JAP 4/3 TYPE ENGINE
Re: HELP PLEASE ROPESTART PULLEY REMOVAL FROM JAP 4-6
On my 2A (2S) I took out the centre nut and the wheel just slid off. If you need to use a puller make sure you can grip behind the whole thing and not on the pulley bit itself.
DanBoy- Life Member
hi there
DANBOY YOU ARE CORRECT FOR THE 2A/S as i have them to
but the 4/1 4/2 4/3 E30
remember this one for your larger japs with a big alloy rope start pulley
there is a 2-3mm hole in the front center of the pulley
SPRAY A LUBRICATION FLUID OIL /WD40
leave to soak for a day or so
then with a block of wood or a soft hammer ie leather or rubber
hit the rope slot in the reverse direction to the engine running one
MINE STARTED TO LOOSEN AND THEN TREADED OF BY HAND
KEV
KEV
