how do you wire a flywheel mag to work off a car coil or simiar ideas PLEASE????????
HI THERE
does anyone know the best way to wire a flywheel mag
to work off a car coil?????
thanks kev
thanks kev
Re: how do you wire a flywheel mag to work off a car coil or simiar ideas PLEASE????????
Here's how.....
http://www.simpletractors.com/do_it/magneto_to_coil.htm
DanBoy- Life Member
nice one dan my boy
thanks i think i can work from this in a round abouts way
ive just bought a second wx11 lzh NOT BEEN SEEN PUBLILY BEFORE AS A OLD MAN JUST DECIECED RECEIVED IS PAYMENT FOR WORK IN
THE LATE 50s and never got a coil for it so was berried at the back of a wolverhampton house garage and forgotten about in a corner
and the engine number is block stamped numbers are in the 1000 range my other early one is in the 3000s and this one has carky green paint on here and there so may be MOD STOCK ,still turns over but needs some tlc
thanks kev
thanks kev
Kev,
You need a 12V supply. use the original points and fit a condenser to suit the coil.
+12V to the coil +. coil -ve to points and -ve12V to ground. Positive ground coil can be used just reverse everything!
I considered this method for my Petter A1, but decided to stick with original. A friend suggested something more modern from the scrappers ie crank sensor and engine management system, but I n ever got as far as looking into that.
I'm reasonably well up on electrical principals so if you need help don't hesitate to ask.
Phil
Phil
Capstan- Born to be wild
cheers phil
that is a clearer descriptin to me alongg the llines of what ive started to do to my wx i was trying to use the working part of the vill coil L/T side and use a small motorbike coil 6volt in to the points system
???????????but will it work????
thanks kev
thanks kev
Good question!
Sounds OK so far but why 6V? Do you have handy 6V supply or did it seem like a good idea at the time.
If I go for a botch (no offense meant Kev) I usually go for bits that are readily available in case spares are needed in the future.
Plus, the condenser (a capacitor) needs to be matched to the coil. One last thing, half the voltage means twice the current for the same spark. This may or may not be relevant to your situation.
Phil
Phil
no your right
its not what i want to be doing with modern syle elctrics and coil
but cant find a coil for a price worth paying for the engines at this time
its cheaper to buy a magneto than a coil for a villiers
just for a roll of wire in gum
Yes, my philosophy is get it working and put it back to original as and when the bits fall into my lap.
Still looking for a three position fuel tap for the A1 tvo.
One always needs a bit of luck with these things.
Phil
Phil
Capstan wrote:Yes, my philosophy is get it working and put it back to original as and when the bits fall into my lap.
Phil
if you find two of them get me one aswell mine is broken needs replacing
if i find 2 will get you one as well , as they turn up in numbers when they appear ,
"BIT LIKE BUSES" lol lol
also looking for a vapourizer stud/bolt for mine waffer thin and will snap off soon
You have a deal on the fuel tap Kev.
The stud you want, is it the single stud that holds the manifold on?
I will have a look in daylight but I think I have the dies to make one.
Phil
Phil
Capstan wrote:You have a deal on the fuel tap Kev.
Phil
yes thats the one
center vapourizer bolt/ stud inbetween inlet, exhurst
if you could do me that i will owe you a burger and a pint at a rally or somthing else
thanks kev
All's good Kev.
I can't get the mixture right on my tvo so the carb comes off for a clean in the near future.
When it does I will make you a copy of the stud.
Phil
Phil
» Villiers Mk25 nut sizes
» flywheels need sorting
» Petter A1 any ideas ?????
» how much wire di i need to wind magnto
» Marine Engine Ideas
