hammer finish paint
hammer finish paint
I need some hammer-finish paint in mid-blue - roughly the colour of the banner at the top of this page - for my Petter cowlings etc.
The trouble is Hammerite doesn't seem do this shade anymore, and anyway I would like spray cans if poss. which narrows the choice even more.
I've looked at Ebay but can't find what I'm after.
Can anyone suggest a supplier who can colour match hammer-finish paint ?
thx
thx
To old to die young
paint
hi have you tried halfords they do there own range of paint they are not esspecialy cheap but its good quality and they also do a petrol proof clear lacquer to protect the paint hope it helps ray
If at 1st you don't succeed hit it with a hammer.
Raymond_Hopwood- Born to be wild
Re: hammer finish paint
I know that some car accessory stores colour match and fill aerosol cans but I don't know if they do a hammered finish. Maybe an hour with the yellow pages and phone everyone local and ask if they can do it. Also check out paint stockists / car body repair suppliers see if they can help or point you in the right directiom.
Can I ask why you need it hammered finish?
Stu
Stu
Hammer finish would match the existing paint, Stu,
but otherwise I wonder if a metallic blue would do.
Guess I'll just have to buy some and try it.
To old to die young
paint
if you get five mins you can pop on the halfords web site and check there stock buy if you look at the pics on my new toy jap 2a that's my engine and the metallic green is not a million miles away from the original hammer finished green that was on them hope this advice helps i also noticed that using the metallic colour gives it a cheeky differnt but not to different look ray
Hammerite isn't paint, it's rubbish.
I don't know about spray cans, but as far as brush applied goes I would recommend this (sorry, I wrote this post without properly reading the OP )....
A really good paint, available in all finishes (including hammered finish), is Rustoleum. They will do any colour from the main charts (RAL or BS colours, so that's about every colour) & it's what they call a self-undercoating paint (like what Hammerite claims to be, but this one actually works), but I find it's best used with a primer for greater durability.
You can order it from most paint suppliers, it's very good stuff, but a bit pricey & the smallest tin is 750ml (& will set you back around £17-£20). But I can recommend it, it is very good stuff with a lovely finish & it really does cover in just one coat (although I gave it 2 coats, as one really only just covers) & really can be painted straight onto bare metal, even onto rust, as long as it's not loose or flaking (but, again, I used a primer for most of my work with it).
I only stopped using it as I didn't need an expensive, self-undercoating paint. But if I needed a hammered finish I would probably go straight for the Rustoleum.
Personally I don't rate Halfrauds.
You might find Rustoleum does spray paint, I really don't know. I know they do aerosol products, might be worth looking into.
Why not use ordinary paint, and solong as you hammer it rite, should be ok.:stick lol::stick lol::cheers:david.
seniorengineers- A credit to the forum
