Lister L crankcase cover query etc.
Hi all, My Long term project is a Lister L , Number34113. my question to you is this; crank case breather is mounted on the door does this make it an early or late model? i have no way of telling being as the spec plate is missing ! the flywheels and crank have matching numbers This will also dictate what type of head it should carry being as the original was missing! Normally i would have stripped this one down but being as it came to me from my home village farmstead i have an attachment to it !.
regards, Karl.
regards, Karl.
100ish Allens,1xListerH, 7xListerD's,3xListerA's,2xListerB's,1xListerJ,1ListerLH,2xListerM's,1xListerN, 1xwolseleyWD11,1xWolsleyWD8,1xRuston1.5PB 1xRustonPB3hp,1xRustonPT, 1xLister CS9/1, 1xAmanco3-1/2hp.
Re: Lister L crankcase cover query etc.
Hi all, problem solved ! A quick email to David Edgington and this was his reply ;
was supplied to J.H.Perriman, Bishop's Nympton,Nr South Molton, Devon. 29/11/22. It is a 2L but almost certainly had the blind cylinder rather than a combustion head-.
