lister d project the rusted thing
+6
interloper
Jake Birrell
Ibonaol
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: lister d project the rusted thing
Good job and I take my hat off to you Squire - given the original condition lesser people would of given up! (me!) - am enjoying the thread - and looking forward to hearing about it!
best
Hamish
best
Hamish
Hi,
Thanks for messages, will hopefully post more photos at the weekend
Thanks.
Ben
Thanks.
Ben
Lister boy- Born to be wild
Hi All
Get all the rubbish out of the sump before you go any further with painting. You dont want any bits in the oil. Thats what i would do i like playing safe with old engines.
But other wise you are doing a Bloody good with her.
Andrew
Andrew
Hi all
We have had a very busy we have clean and painted the carb, we have start to put it back together we put the piston in and all the stuff to make it turn over so we think, but will not turn over we are a bit confused??? Need help, we Broke one piston ring but we had on which is luckey, we painted all the part but not fuel tanks strips do we have brass ones are stick with old ones.
The painted carb and flywheel
[/URL
putting the piston in
[/URL
hows the engine progressing boys
not heard an update on forum for a while mate
Hi kevkevjhnsn wrote:hows the engine progressing boys
It is been to wet with use to put the top coat of paint on . So the project has stopped for a couple of weeks.
Hopefully I can put the paint on soon.and get it up and running.
Thanks Ben
hi all
sorry for no posts but there was only one job to do and it was top coat of paint.
does anyone no where top dead center is on the mag so we can get the right timing.
Looking good, Nice repair!
Lewis MacRae wrote:Looking good, Nice repair!
thanks very much
Is that been Sprayed?
yes we sprayed itLewis MacRae wrote:Is that been Sprayed?
youve missed a bit
Inside the square bung above the flywheel and under the control rod for the carb...
Aaaannnnddddd.... Your throttle spring bolt is 90degrees out so you will faff the paint when you turn that to the right place.
I feel a bit mean picking faults but I have, sorry. Feel free to look at my threads and find fault with those.
We will be putting on a second coat of paint and waiting for the fuel tank to come so will need the paint out again.Villiers wrote:Aaaannnnddddd.... Your throttle spring bolt is 90degrees out so you will faff the paint when you turn that to the right place.
lister boy
what thinners are you using for top coat
to make sure my primmer dont react later
Enamel Thinners PT8kevjhnsn wrote:lister boy
kev you can use synthetic thinners thats what i been recomended to use . worked finekevjhnsn wrote:lister boy
Great job!
Jake Birrell- Born to be wild
Page 2 of 2 • 1, 2
» LISTER D CAD PROJECT
» Lister D project next
» Unplanned Lister CS 6/1 project
» New lister CS SOM project ..Thorghts
Page 2 of 2
