Gland Packing
Gland Packing
Hi, could somebody tell me what size gland packing and how much I need for a Lister H2 pump.
Thanks, Bernard.
Thanks, Bernard.
steamman- Expert
Re: Gland Packing
matt 86 is the feller for this, as he did one a while back
Re: Gland Packing
1/2" i do believe but i will have a look to see if got the size i used on it in the shed still and measure it .
Re: Gland Packing
Thought it was 3/8???
Re: Gland Packing
Villiers wrote:Thought it was 3/8???
i have not got the pump so its not fresh on my mind Rob .
Re: Gland Packing
I think it might depend on whether it is the water pump or the high pressure spray pump version of the H2? The spray pump has a smaller diameter plunger, usually made from stainless steel, so I think it might need wider gland packing? If so, let us know what type of H2 pump you have (a good quality photo should help).
Jules.
Re: Gland Packing
Hi the Lister pump is a water pump.
Thanks, Bernard.
Thanks, Bernard.
steamman- Expert
Re: Gland Packing
I've just been out to the shed to measure the off-cut of gland packing left over from mine, but my H2 is the spray pump version... so that's not much help, as I don't know if the water pump is the same or not!
Jules.
Re: Gland Packing
I would have thought the packing is the same size as the face that goes into the gap on the plate that holds the packing in...
Get my drift??
Get my drift??
Re: Gland Packing
Got your drift.
Thanks.
Thanks.
steamman- Expert
» Lister H1 gland packing
» lister h2 gland packing ?
» Joneseys new toy and postage and packing
» Lister Junior - re-packing fuel pump
