trailer help please
+2
NoelA
6 posters
trailer help please
hi guys.my little trailer is a flat bed.no sides.thinking of put my engine on it.but is wot I would like to know is as it you can see the car lights eather side of it
do I need lights on the trailer as well or just a number plate.
thanks dave.
thanks dave.
Diddy- Life Member
Re: trailer help please
I am fairly sure that you should have lights.
Yes you do Dave easiest and a cheap way just use a trailer board.
got to get the car wired up now then.bugger.thanks guys.
Diddy- Life Member
well dave its law if you're towing a trailer mate , not a hard or expensive job either well if you know how .
Some cars it's easier to buy the specific loom that just plugs in, especially if it is intelligent and knows when it has a bulb fault.
NoelA- Born to be wild
The one car we had it use to sound like a strangled cat when the indicators on the trailer were on and braking
Mattjones- Born to be wild
Was that jus the buzzer or something wrong with it? You can get bypass relays for modern vehicles I did mine without any problems.
[quote="Mattjones"]The one car we had it use to sound like a strangled cat when the indicators on the trailer were on and braking [/quote]
Sounds like a short circuit on the trailer lights somewhere. Bet you are one of the many that has all lights flashing when the indicator is on and the brakes are applied...
You'd need to do that for the MOT anyway, unless you plan to take the hook off at MOT time.Diddy wrote:got to get the car wired up now then.bugger.thanks guys.
It turned out to be dodgy wiring on the car we just use to fiddle with the connector plug till it worked somewhere near right
