lister b help
lister b help
Post by graham361 on Thu Jul 17 2014, 09:22
hi to all i have a lister b and someone has tried to get gib key out on one fly wheel they have drilled in about 1 inch how far can i drill in as to not damage anything have orderd a new key it is 4hp and dont want to run as it is and not sure if the gib keys a long or short type many thanks regards graham
graham361
Re: lister b help
Post by Foden on Thu Jul 17 2014, 15:43
Well Graham, if the key was fitted properly it should extend slightly beyond the flywheel width at least (can you see the end of it?) so you can drill that far, and there shouldn't be anything behind the flywheel to damage.
