RAD WELD lister d
RAD WELD lister d
I have just read about the use of rad-weld in a lister d , chap was saying that water was getting into the oil sump so was adding rad-weld as a cure , is there any weird reason to do this and would it work .
gerrybongo- Born to be wild
Re: RAD WELD lister d
if your getting water into the oil its either head gasket gone or a crack in the cylinder wall or in the jacket somewhere, in which case it is probably easier to find a replacement block or head...
PROPER JOB
Matth92- Life Member
and I second the matth92 comment, also rad weld is designed for pressurized cooling systems to stuff it into the gaps.Matth92 wrote:if your getting water into the oil its either head gasket gone or a crack in the cylinder wall or in the jacket somewhere, in which case it is probably easier to find a replacement block or head...
» Lister D??
» Lister D??
