3HP Petter A1VO
3HP Petter A1VO
Hello.
This is my 1949 3hp at 1500 RPM Petter A1VO.
It is a near complete engine with only an exhaust and starting handle missing, Fuel tank is not in picture but does have one which was an afterpurchase. The only part that needs replacing is the spark plug which was expected at the time. The engine is fine and the piston and block look decent with no cracks. The mag has a spark which is a good sign and doesn't need checking just a quick clean.
I will update as i do some more with it.
Chewzacca- I really need to post more
Re: 3HP Petter A1VO
Hi all,
Has been a long time i know (Completely forgot about here, although posted it on facebook) but i thought i'd share some pictures of what im at at the moment. I've spent this summer restoring it.
I apologize aswell the photos aren't all in order due to a phone change.
And the Finished (ish)Result:
Still need to add the small fuel tank and connect up the fuel lines, add the silencer and decals and could do with another coat of paint!
From this:
To This:
Video of its first run in 45 ish years (Apologies if anyone can't see it i'm trying to Upload it to Youtube
https://www.facebook.com/AndersonAgri99/videos/1101513956601381/
Hope you like it! Its not perfect and theres still room for improvement but for a first attempt im pleased. Hope to see you on the Rally Field in 2017!
From this:
To This:
Re: 3HP Petter A1VO
Nice job.
Re: 3HP Petter A1VO
Very nice
Farmenginerd- Born to be wild
Re: 3HP Petter A1VO
Very good well done
