Lister Dating
+14
interloper
toaster
ED3229
Peter D Owen
ou enjin
Peter
lister
Jezmiester
18 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Lister Dating
If anyone would like to try and find out some history, and dates on a lister they have the man you need to email is David Edgington email him on this link mailto:info@stationaryenginebooks.co.uk he is very helpfull
Re: Lister Dating
Ive tried to email him using this email and it didnt seem to reply back!
Also i will try to find David Edgintons Home Address
Statman- Life Member
Re: Lister Dating
leave it with me ill see if i can dig up more possible leads
Re: Lister Dating
If you check this site out it gives you some engine dating information for Listers:-
Happy cranking,
Stu
Happy cranking,
Stu
Re: Lister Dating
Stu's site is very good, if that fails ive been digging and the best way to get hold of David is by post, if you post him engine details you will have a signed letter back from either him or his wife address to follow
Re: Lister Dating
Ryan did you manage to Find David's address? If so can you pass it on to me as I'd like to see what information he can give me on my Lister J.
Re: Lister Dating
no now im online again i will try but did hear through the grapevine he is responding to emails again, leave it with me
Re: Lister Dating
I have tried emailing him, just last week so maybe to soon for a reply. So I'll let you know if I get a reply or not.
Re: Lister Dating
I emailed this address and another about three weeks ago and had no responce so i would go for snail mail.
His Address is
Lodge Wood Farm
Hawkeridge
Westbury
Wiltshire
BA13 4LA
Good Luck All
Jez
His Address is
Lodge Wood Farm
Hawkeridge
Westbury
Wiltshire
BA13 4LA
Good Luck All
Jez
Jezmiester- Posts : 3
Re: Lister Dating
Thanks Jez, I've tried to email him with no success, so now I'll try a letter. I'll keep you posted if I get a reply.
Brilliant i sent a 2nd email this week
to another email address but no joy, ill also post this address in the suppliers section, thank you jez
David Eddington's Lister Dating
Write a letter with your serial numbers and engine details and you should get a letter back with the year your engine was made and maybe some history
David Eddington,
Lodge Wood Farm
Hawkeridge
Westbury
Wiltshire
BA13 4LA
David Eddington,
Lodge Wood Farm
Hawkeridge
Westbury
Wiltshire
BA13 4LA
Re: Lister Dating
Thanks for your help Ryan, letter has now been posted. I'll keep you informed of the results.
Re: Lister Dating
Just to keep you up to date I wrote a letter to David to get the date etc for my engine. I posted the letter on Saturday and the reply came back today Tuesday, can't get much faster then that, so this is the best option to contact him.
So my Lister J type was built 12/12/1926 and supplied to a company about 3 miles from where David lives. Company name was Reeves of Bratton, Wilts anyone know anything about this company?
Re: Lister Dating
Stu I think they were a building firm, they made there own beams and stuff.
Not sure weather there still going they were when I was a Lad.
Wiltshire born only Emergrated to Dorset 2 years ago
Re: Lister Dating
Chris, All that David's letter said was Reeves Of Bratton were in business until sometime in the 1960's and took many Lister engines. Nothing to indicate the business they were in or what the engines were used for.
LISTER D POST 1945 ENGINES AND DATING......
if your engine number begins with 1/ or has a number with less than five figures, it was built after 11/3/1946.
because at that time engine numbers had reached 199999 and the decision was made to introduce a shorter numbering scheme starting with 1/1000. this system continued until DECEMBER 1951 by which time engine numbers had reached 1/77820.
At this juncture a further change was introduced because from 1952 onwards every engine number began with 1 at the start of each year and to avoid any confusion the SPEC.number was arranged to give the year of manufacture of each engine.
So for example DH2 was manufactured in 1952,DH3 in 1953, DH4 in 1954, DH10 in 1960 etc. hence an engine bearing the following number-281 DH5 was manufactured in 1955.
The majority of engines built from JUNE 1948 onwards were built at WROUGHTON,near SWINDON, production continued until about 1964.
Fortunately a little more information has been made available and enables the previously produced dating guide to be extended to 1958.
a final point concerning the reading of SPEC numbers on the later engines.
Instead of DH3..you might see DR3 or DZ3, so to avoid any confusion this small list may help our forum members in the future
SPEC...DR= R means radiator cooling.....
SPEC...DZ= Z indicates REVERSE rotation..however to add to the confusion..R was often used on earlier engines...
SPEC...DK= the K Stands for kerosene......
SPEC...DH= H..of course meaning hopper cooled......
SPEC...D2= sometimes used to determine output...IE..2hp.....
If your SPEC plate is missing from your engine you should be able to find the number stamped on the flywheel crown......
hope this helps some of our members....
mike d....
mike d....
Can anyone date this lister D
en number 3753, (think it may be a later model), DH7 1.5HP 700rpm. Thankyou,
Re: Lister Dating
dh7 means it was built in 1957
lister- Born to be wild
Lister engine history and dating
ryan wrote:If anyone would like to try and find out some history, and dates on a lister they have the man you need to email is David Edgington email him on this link mailto:info@stationaryenginebooks.co.uk he is very helpfull
I have recently purchased a Lister D type petrol engine, 2 HP, 1000 RPM, S/N 2814.
Would you be able to provide information on the approximate year of manufacture?
Thanks in anticipation
Peter
Email [You must be registered and logged in to see this link.]
Peter- Posts : 3
Re: Lister Dating
Do you also have the spec number of this engine? I think it is one of the last years.Peter wrote:
ect....
Let us know everything that is on the brass plate.
ou enjin- I really need to post more
Lister D2 date of manufacture (cont)
The brass plate has on it:
No 2814D2
Spec (blank)
HP 2 RPM 1000
No 2814D2
Spec (blank)
HP 2 RPM 1000
Peter- Posts : 3
Re: Lister Dating
2814D2 is your serial number and spec number combined.
It is serial nr. 2814 and spec D2, and is built somewhere in the beginning of 1952.
Page 1 of 2 • 1, 2
» Help with dating Lister D
» lister d dating
» Lister D with sheep shearing attachment
» Lister Engine Dating
» lister D dating and info
» lister d dating
Page 1 of 2
