Soldering fuel pipes.
I need to change fuel connections on a fuel pipe. However, I don't have/can't afford/don't have the skills to solder fuel pipes.
Any ways I can get round this would be appreciated! What trades could help me out? Would a local garage be able to do this for me?
Thanks
Thanks
iangt- Born to be wild
Re: Soldering fuel pipes.
Could you use a compression fitting instead?iangt wrote:I need to change fuel connections on a fuel pipe. However, I don't have/can't afford/don't have the skills to solder fuel pipes.
Thanks
Get an after life..
casper- Expert
I know what you mean about buying more tools that might not get used a whole lot but all that you would need is a small propane torch a bit of new solder and some flux. That might prove cheaper than paying or trading some one to do it because you might find another job for the torch .Cheers and good luck Mike
Mike Unwin- Born to be wild
thanks both. I am a real newbie, got to ask what a compression fitting is?
It would a mechanical type joint just basically a nut on the fuel line pressing against a little brass collar to form a seal. Good luck Mike
You could try here:
http://www.vintagemotorspares.com/
Select Miscellaneous from the left hand sidebar and then scroll to the bottom
Good luck.
Good luck.
