Gib Key Extractor
+10
Robotstar5
nickholden 1
HobbyPaul
tony RA
chiefy
Locknut
14 posters
Gib Key Extractor
I needed to extract the Gib key on my Petter A1 and after looking at the style available for the Lister D I thought how hard can it be?.
I got a square piece of 10mm plate, holesaw to the shaft diameter and 4 M10 tapped holes in the corners, then quite a lot of filing later I had this...
A1Key01 by Robert Starr, on Flickr
It fitted a treat...
A1Key02 by Robert Starr, on Flickr
Nearly there...
A1Key03 by Robert Starr, on Flickr
The end result, looks like I was lucky the head didn't pull off as a previous owner had attacked it with an angry grinder by the look of it
A1Key04 by Robert Starr, on Flickr
Stuart.
Nearly there...
Stuart.
Re: Gib Key Extractor
Nice work Stuart - I'm afraid I was lazy and bought one.
Hi Stuart,
What a good idea.A lot of work but you end up with a very effective tool .
Kev.
Kev.
Hi Stuart,
All your mates will be sending for you now they know you have made this tool nice one.
Regards,
Chiefy.
Regards,
Chiefy.
chiefy- A credit to the forum
Nice job Stuart and very rewarding it/s a bit of work but when the key comes out that's when you get you/r Buuuzzzzz
@woodsman where did you get your puller from. i could do with one to do my A1 as well.
Andrew
Andrew
[quote="Andrew1971"]@woodsman where did you get your puller from. i could do with one to do my A1 as well.
Andrew[/quote]
Ebay.
Andrew[/quote]
Ebay.
Nice work...ow did you get it behind the key to start?
Lister D 1949? ... Villiers MK25 1964 ... Villiers F15 ... Hopefully a John Deere in the future
HobbyPaul- Expert
HobbyPaul wrote:Nice work...ow did you get it behind the key to start?
The large notch fits over the head of the key then rotate the puller a few degrees so the smaller notch engages behind the head, the second photo shows how it fits.
Robotstar5 wrote:HobbyPaul wrote:Nice work...ow did you get it behind the key to start?
I worked that bit out from the good photos...
but isn't the gib key flush on the flywheel so how did you make enough space between gib and the flywheel in order to use the jig you made.
HobbyPaul- Expert
The Gib key should have at least 10-12mm behind the head when fitted correctly, it took me a lot of filing and test fitting of the new key to get it (nearly) right
Andrew1971 wrote:@woodsman where did you get your puller from. i could do with one to do my A1 as well.
Andrew
https://www.ebay.co.uk/itm/233238943392
seems a bit pricey
When you cant make your own what other option is there.
Andrew
Andrew
Would that be a claas gib key remover
if so i remember them doing a right and left handed version
Nick
Nick
Nick
nickholden 1- Posts : 3
I made one of these years ago, does the job fine.
I tried making one but the steel just buckled
I am trying to remove the wheels off an Allen scythe at the moment and this looks the job...any chance of measurements /thickness of plate /size of bolts?
Howardman- I really need to post more
Claas gib key tool
Hi,do you know anywhere that does these for less than £30 please? I need to get a couple of gib keys out but I can't get to the end of the shaft,so I can't use the type of puller shown at the start of this post and as someone else said,the steel would need to be very hard to make the Claas type.
Cheers,Graham.
grassey- I really need to post more
You can get a straight one for £25 https://www.ebay.co.uk/itm/TAPERED-KEY-DRIFTS-STRIAGHT-CURVED-/182963279071
Thanks Stuart.That is a bit better.
Or get some flat bar, 8mm thick and cut your own. Doesn't need to be long, the one I use most is only 6 inches and I've never had any issues.
Thanks.Hopefully a mate is going to make me one.I have only just started restoring so haven't needed one until now.
