Stuart Turner AF4
Stuart Turner AF4
Having problems getting a Stuart turner AF4 to pump properly any ideas out there ,it only seems to work with the springs taken out and even then there isn't a lot of pressure
Albert1728- Born to be wild
Re: Stuart Turner AF4
Apologies Arthur - misread your post so have moved it to correct section.
You right want to try these people for spares/advice: http://www.amospumps.com/Stuart-Turner-Spares.html
Woodsman wrote:Apologies Arthur - misread your post so have moved it to correct section.
Don't waste your time here, I asked them some time ago and they have NO spares for Stuart Turner pumps
Garak- Life Member
Albert1728 wrote:Having problems getting a Stuart turner AF4 to pump properly any ideas out there ,it only seems to work with the springs taken out and even then there isn't a lot of pressure
No pressure is a symptom of worn piston seals or pressure loss past the piston rod gland.
Garak- Life Member
