Vee Belt Pulley WANTED
Am needing a vee belt pulley that has a centre fixing hole with a HALF INCH measurement, would prefer a grub screw fixing type please with a diameter of MORE than 6 inches, cast or alloy, I have done a bit of searching on that auction site but could not find one the required size.
If you have one that is not required please message me with your asking amount and what you think postage would be, cash is waiting.
Could possibly take a taperlock type as long as it is in good condition and complete
Pulley found, and purchased.
donp- A credit to the forum
Re: Vee Belt Pulley WANTED
Not sure you are going to get a bigger than 6 inch vee pulley with only a 1/2 inch bore as most commercial ones only go down to 5/8 inch bore. You may have to select one with a pilot bore, or unbored, and bore it out yourself.
» V Belt pulley
» 1.5" bore pulley or fly wheel wanted (maybe found one)
» Petter A Series II - Belt Pulley Gib Key Removal
» wanted working rs1 mag coil wanted
