Bristol compressor
Bristol compressor
My latest ebay purchase arrived yesterday... little compressor made by Bristol Pneumatic Tools Ltd of Fishponds, Bristol.
Anyone know if Halfords stock 'Brismatic' grease? I'd hate to void the warranty...
Home made air cleaner, I can remember my Dad using 'Rozalex barrier cream years ago.
And this is the idea for it.
I was hoping it would only need a cosmetic restoration, but it's seized (the pulley is turning on the shaft) so a strip down is in order. I'll keep you updated.
Re: Bristol compressor
Unless you have some "Brismatic" grease you won't be able to use it
To be honest I would have a go at it.loads of oil to stand for a few days. Just hope nothing breaks,Good luck if you try.Arthur.
dunitrong- Expert
dunitrong wrote:To be honest I would have a go at it.loads of oil to stand for a few days. Just hope nothing breaks,Good luck if you try.Arthur.
I may try to free it off, I did get the bottom end to move a bit with the head nuts off so the cylinder moved with the piston. The difficulty is getting to the bore to clean it up, the conrod passes through a slot in the crankcase and the piston is nearly at TDC.
At the end of the day, I've nothing to lose.
Have a look at this thread...
https://ukengineforum.forumotion.com/t8394-rust-removal-using-citric-acid?highlight=citric
» Bristol Compressor
» Bristol Air Compressor Set
» Bristol and Wagon Victoria 3hp
» late night shopping in Bristol
» Compressor
» Compressor
