Valve timing Lister D
I am confused! I am reassembling my lister D Matblack advised me that the cam lobe should be vertical at TDC there are two vertical positions one where the cam lobe ( Peak ) points down both valves fully closed and one where the rounded area of the cam not the peak points down also both valves are closed?? Before I get it badly wrong can someone clarify. Much appreciated.
Shane.N- Born to be wild
Re: Valve timing Lister D
The peak of the cam should be vertical (12 o clock) and the rectangular cut out in the trailing shaft should be vertical as well.
Thanks pete. hopefully get it all back together this weekend
Shane
Shane
» Alco/P3 valve timing?
» Petter A1, valve timing
» lister d timing
» Lister d timing (again)
» Lister D Timing
» lister d timing
» Lister D Timing
