Amal carb ID help
Re: Amal carb ID help
Model numbers are usually stamped into Amal carbs. Are there no numbers on your carb ?
blue cat wrote:Model numbers are usually stamped into Amal carbs. Are there no numbers on your carb ?
I can't see any numbers, hence the question. Do you know where they are usually located?
Usually on the main body, but not all are stamped with the model number.
» amal carb 379/78
» Villiers F15 with Amal carb - is this a good idea?
» Set up for an Amal carbie on Ruston PT
» Float bowl top wanted for lister D
» Amal carburetter identification
