Gasket Material?
Re: Gasket Material?
Cornflake box. When it's bolted up there is very little that the water can do, because it is nipped up tighter than my bodice (Need help to keep this hour glass figure) it won't leak as the water cant get in.
Agree with Appletop, yet again , but I wipe a thin smear of grease on both sides to help seal the surfaces.
Martin P
Martin P
Cheers, looks like Mrs Robo is going to lose the side out of her Cornflake box because I normally eat Shreddies
Shreddies boxes I find are too thin and weedy...
Whereas Weetabix bursts the bolts asunder...
The Boy's Own Paper often recommended oiled brown paper for gaskets in their constructional articles.
George B.
George B.
georgineer- Born to be wild
you have to be careful using some materials, as an experiment when I restored my Hopper called Lister A I used liquid gasket, I assembled the crank bearing assemblies without gaskets and found the gasket material actually allowed end float but without them I couldnt turn the crank.
When I'm making gaskets for things like this, I use an old felt pen or ink pad to ink the mating surface of the component. I then press this down onto the cardboard or gasket paper to get a good outline of the shape of the gasket required.
For both materials, the thin smear of grease is certainly a good idea.
PetterAS- Born to be wild
» Head Gasket material.
» What's the best material for an ignition tube?
» Gasket......or not?
» Head gasket material
» What material is best to use for water tight gaskets
