Red oxide metal primer
Most of my 'new' Lister D will require re-painting. The fuel tank in particular is in need of sprucing up. I know about Mid Brunswick being the correct colour top coat and gloss is the most accurate to the original but my question is a red oxide ok for a primer/undercoat?
Many thanks.
Many thanks.
Re: Red oxide metal primer
That's what I use, 1 coat red oxide, 2 undercoat, normally a dark grey one and 2 top coats.
I normally use Blackfriar red oxide primer, seems to give good results
https://www.blackfriar.co.uk/product/red-oxide-metal-primer/
Done mine with red oxide, give it all a good clean first then a rub down and another clean. The primer goes on well and left to dry over days, second coat was given the next day but after that I left it. Then two coats of brunswick green and it finished lovely. I think the red oxide was from screwfix but not sure, I have used in on quiet a few out door steel works and always found it very good. Dont be in a rush let it dry properly, that pays dividends.
DaiCap- Born to be wild
» Metal spraying.
» metal in the size you want.
» 1st time metal solderer ...
» Best paint primer
» Lister D White metal Big End bearing
» Best paint primer
