Villiers Mk10 V engine
Until recently I thought the "V" engine was only made in Mk20 & Mk25 versions.
Looks like there was a Mk10 version too...
Cleaned the paint off with thinners and wire wool to find this
Makers stamp on the cowling dates it to 1944
Only seems to be missing a HT lead, but the coil reads OK so fingers crossed.
Re: Villiers Mk10 V engine
An early one then, they didn't have lip seals on the crankshaft but used a spring loaded bronze gland on the front and just a return scroll on the magneto side.
I always thought that Villiers used the "V Engine" name during WW2 as a disguise, just in the same way that Petters just put a "P" on their military PU8 engines.
blue cat wrote:I always thought that Villiers used the "V Engine" name during WW2 as a disguise, just in the same way that Petters just put a "P" on their military PU8 engines.
But helpfully cast 'VILLIERS' in big letters on the crankcase...
mattblack wrote:blue cat wrote:I always thought that Villiers used the "V Engine" name during WW2 as a disguise, just in the same way that Petters just put a "P" on their military PU8 engines.
The boys at Villiers were obviously not as sharp as the lads at Petters then
It has "VILLIERS" cast into the Mk.10, but my Mk.25 "V" engine only has casting numbers but no name.
» villiers mk10 v engine flywheel wanted
» Villiers MK10
» Villiers Mk10
» Villiers Mk10
» Villiers MK10
» Villiers Mk10
» Villiers Mk10
