Wolseley WD2 restoration
I'd been after a Wolseley engine for a while as they were made in Birmingham and got this one late last year.
Engine No.7497 dispatched to W. J. Cooper of Newport Pagnell on 4th June 1945
The plan is to strip, clean and refurb back to as close to original as I can get it.
Started off by removing the flywheel and found the Gib key had been filed too narrow allowing the flywheel to turn slightly on the shaft so it was only the taper locking it in place
Took the head off and it didn't look too bad, bore OK and no play in the piston
Cleaned up nicely
and so did the head
Started cleaning the paint off and found a large patch of body filler on the flywheel side where they are prone to frost cracking
Checked inside as best I could and it looks like a repair so fingers crossed
The only casualty so far was one of the water jacket door studs sheared off
Penetrating oil, heat and patience got the remains out
Someone on another forum made me a replacement, sorted
More worrying was finding a pin when I was cleaning the sump out
This was identified as a valve retainer, but mine were both present
I can only think it had been dropped in the past and instead of rummaging in the sump a replacement was fitted
Cleaned up nicely
and so did the head
Re: Wolseley WD2 restoration
I think it had quite a history, while removing paint I found red, yellow, blue, green, grey, black and gold paint in various places!
Lots of scraping and wire wheeling, brushing etc. later
I did find an interesting casting mark
I did my apprenticeship in an Iron foundry that was part of the Qualcast group
A couple of coats of red oxide primer later
Followed by a couple of coats of enamel
I decided to build a new trolley while the engine was light enough to move around
Some nice American ash cut and glued together
Axles made
Painted and fitted to the trolley
Looks nice sealed with a couple of coats of Osmo Polywax and ready for the engine
Engine on it's new home
The black paint was really "gummy" and difficult to remove
After a lot of wire brushing I admitted defeat and had it media blasted
Then a couple of coats of primer
Followed by a couple of coats of enamel, looks a lot better now
Axles made
The water drain tap didn't look right
So I got an original drain plug/bung
Covers cleaned and masked up ready for painting
Lots of nice bits ready to go back on
Nice details on this cover
So the best part of an hour later using a tiny paint brush
Flywheel cleaned
Flywheel and pulley painted Red to match the wheels
The price of Gib keys has gone up 25% in a year!, after a couple of hours of blueing and filing I fitted the flywheel
Flywheel cleaned
It's a Wolseley again
Made some gaskets and started fitting the covers
It's nice to see good old fashioned points these days, and made in England as well
The timing was out by one tooth when I took it apart
So I timed it to the manual and fitted the magneto
New HT lead and terminal
Painted the new silencer and polished the float chamber top
Just waiting for the tank
The original tank had seen better days
So I bought a new one
Needed some body filler
and prepping for paint
A couple of pics of the finished engine
and a short clip of it's first run
Nice one Stuart!
Appletop wrote:Nice one Stuart!
Made a good job of that, I actually sold my WD2/Fullwood dairy set about a month ago now as it hadn't been rallied for a couple of years. That was the first engine that I rebuilt in our kitchen around ten years ago, there have been many more since though! I still have a spare head for one in the garage somewhere, it's painted red which a lot appear to have been.
» Wolseley WD2, first restoration
» wolsley wd
» Wolseley WD8 Long Period Restoration begins!!
» My Wolseley WD2
» Wolseley WD8
» wolsley wd
» My Wolseley WD2
» Wolseley WD8
