briggs twins
briggs twins
hi these are two briggs and stratton twins i made around 15 years ago great fun to hear running and reliable
red one is the 1st one i did using tecumseh carbs
grey one is a honda motorcycle carb both will run happily under load at around 5000 rpm and still run now
i had a lot of fun doing these and have since made a tecumseh tripple
regards john
https://i.servimg.com/u/f34/20/27/47/58/red_br11.jpg
regards john
Last edited by the engineer on Fri Oct 30 2020, 07:45; edited 1 time in total (Reason for editing : first post and fun with getting photos right)
the engineer- Born to be wild
Re: briggs twins
Nice to see you back John.
I've always fancied marrying two Villiers as a vee or boxer but my engineering skills are almost nil in the machine shop.
Re: briggs twins
yep got lost when i got a new computer trying to find every thing again
Re: briggs twins
They look good.
How are the cranks phased on the twins; is it:- both pistons at tdc, at the same time, or, one at tdc whilst the other is at bdc?
Re: briggs twins
they are both parallel i did one at 180 and had to go twin carb to get a stable idle on both cyls
with single carb it always had one weak cyl at idle due to valve overlap robbing manifold vacume
» Anyone familar with the Enfield flat twins?
» Another Briggs & Stratton
» Very old Briggs and Stratton
» 2hp Briggs & Stratton
» 9hp Briggs & Stratton
