WICO series A mag - Stop button
Hi, my Mag has a stop button on the side which does not work.
Ths stop consists of a brass thread and a tab which when connected by pressing should stop the spark.
The tab has continuity with Ground / Earth, so thinking when you join the tab to the brass pin it should cause a short to earth and stop the spark?
After taking appart to investigate, found the brass thread is connected to another brass thread on the other side (which is covered by a plastic cap). Both threads are electrically connected to each other and both isolated from anything else, hence all I am doing when pressing the stop is connecting these two brass threads to earth, so no wonder its not doing anything!
Assuming these two brass pins should also have a wire connecting them to something else, but not sure what / where.
Cannot seem to find a wiring diagram that shows the connections, so any help would be appresiated as I would like to add the missing connection
Thanks Nij
Thanks Nij
NIJ- Born to be wild
Re: WICO series A mag - Stop button
Hi Nij,
Haven't had my mag apart but I would assume that that the connection between the buttons should also connect to LT side of the coil.
I can let you have a manual if that would help - PM me with email address.
Result
After some experiments and the view of the parts list (thanks Woodman) it became clear that the two brass threads should also be connected in at the same point the condenser is, such that when the stop button is pressed an earth fault is created and the spark stops.
Have added in a new bit of wire (the Brown one on the photos) now all works as it should.
P.S. I know my soldering is not the best! lol
» Petter A Series II - Wico A Magneto Issues
» Wico series A magneto
» Wico Series A magneto types
» WICO series A mag - Distributor Cap for Twin
» jap 2a stop switch
