BTH M1 MAGNETO / CROSSLEY 1030
Afternoon.
Plodding on with my Crossley 1030 overhaul. I have no spark. Tried the basics of cleaning points/plug, remaking plug lead connections etc. Mag now removed from engine and its clear its had a tough life judging by the tired look to many of the screw heads etc.
Is there a basic observers book of “what to look for” for the novice magneto stripper ? Had the points and backplate off, all seems clean/dry. Can’t see a condenser anywhere though ?
Any guidance appreciated
Terry
Terry
Waggers- Born to be wild
Re: BTH M1 MAGNETO / CROSSLEY 1030
My first port of call would be to check resistance between HT terminal and earth - open circuit indicates a break. Never had an M1 so cannot offer anything further but for a few quid you can get a manual here.
https://www.nationalmotorcyclemuseum.co.uk/product/bth-magneto-1931-instruction-manual-for-magnetos-types-m1-m2-mc1-and-mc2-croft2733/
Thanks. I will try the resistance test first.
The condenser is inside the armature on the BTH M1.
Ah. Is it something i can get at and replace easily as i have it partially stripped ?
Thanks
Thanks
[quote="Waggers"]Ah. Is it something i can get at and replace easily as i have it partially stripped ?
Thanks [/quote]
Nope. I am fairly sure it's a rewind job.
Thanks [/quote]
Panic over
Checked for open circuit between pick up and earth and tested OK. Messed with position of points on the spindle, turned through 180 degrees, hey presto, i have a spark. ! I have ordered the manual from the National M/C museum which hopefully will tell me how to set it up properly. The mag was still attached to the engine but flopping about as bolts loose when I got it. Timing marks on both sprockets were not lined up so hence my initial concerns
My thanks to the responders on my query, most helpful
» Crossley magneto
» Crossley 1030
» crossley 1050
» HELP, dating a crossley 1030
» Crossley and Magneto
» Crossley 1030
» crossley 1050
