Petter A1 manual and gear removal
+2
Skips1
6 posters
Hi, new to stationary engines and have started on the strip down of my recently acquired Petter A1 resto project. It's not fighting me yet but I'd appreciate some advice on removal of the gear wheels.
There's not much clearance between the gears and the case to get a puller behind. The "crank gear" and "timing gear" both have a number of threaded holes which appear to offer opportunity to wind in suitable bolts (presumably Whitworth thread?) to push the gears off their shafts. And how is the magneto drive shaft best removed after the gear has been removed? Any advice would be greatly appreciated.
If anyone can provide a pdf copy of a workshop manual I'd be grateful.
Thanks,
Alan.
Thanks,
Alan.
Skips1- I really need to post more
Re: Petter A1 manual and gear removal
Hi Alan.
PM me with an email address and I'll send a copy of the manual.
Many thanks, will do when 7 days have expired
Hi Alan, A lot of the threads on the Petter A1 are BSF (not Whitworth).
Many thanks for the intel, will bear that in mind
Good call from blue cat.
Suggest you start looking for cheap digital caliper, thread gauge, and thread tables - Zeus Precision Data Charts and Reference Tables for Drawing Office, Toolroom & Workshop is a good start.
Check around before buying from Amazon - silly prices sometimes.
Hobby quality digital caliper from your local German discounter, Screwfix, or Toolstation for about £20 and Silverline thread gauge for about a fiver.
The camshaft is one big lump the gear does not come off. You should have a small plate with
two bolts close to the gear wheel undo them there should be some shims behind it. A little wiggle should come out. Make sure you know where the timing marks are. The four bolt holes
are for attaching a shaft to it if you have the parts to do it.
Andrew
Andrew
Many thanks Paul and Andrew, that all makes sense.
I bought a set of three 3 leg pullers for about £12 on eBay.
The smallest 3" I think? I modified on a grinder
This the fit behind the crankshaft timing gear.
I modified a spare bolt to fit the crankshaft, countersunk to take the puller screw.
Alignment marks for gear timing.
Best manual but not entirely helpful.
Make sure this oilway channel is at the top when reassembling. Ignore my fly weights yours will most likely be cast iron.
Andywaters- Life Member
Petter A1 manual. Would you please email me a cpy of the manual? jakkieblom@gmail.com I am in South Africa and postage is too expensive!
Petter A1 manual. Would you please email me a cpy of the manual? I am in South Africa and postage is too expensive! I may only send you my gmail address after 7 days!
jakkieblom- Posts : 2
PDF sent.
Word of advice - don't post your email address in open forum. Too many 'bots' about
Please start a new thread in 'New Projects/Restorations' when you get going and a few words in New Members would be appreciated
Good luck!
Good luck!
» Petter A 1945 restoration
» New Project Petter A1 Restoration Manual URGENTLY Required
» Petter m main bearings stripdown help and mag gear
» petter AA1 injector pump removal
» Petter A Series II - Belt Pulley Gib Key Removal
