Petter AD1 not starting....
.... it has started and run in colder weather, it won't anymore, and nothing has changed. It has started backwards in the past, and I suspect that it's kicked back a couple of times. My suspicions are that the injection timing has drifted- how do I quickly check the timing? Do i understand... that you *add* shims to *retard* the timing, and vice versa? Hey, I'm new to this. Thanks for any help.
brian hughes- Born to be wild
Re: Petter AD1 not starting....
Yes, increase shims to retard start of injection.
The LISTER PETTER manual gives the procedure and settings on pages 55 to 57.
I googled it and http://engine.od.ua required me to allow notifications; I think that might have been a mistake, as I keep getting messages from some rather naughty ladies.
I suggest you use a different site.
» Petter PA2 - 'not starting'
» Petter Universal PU8 starting problems
» Petter A1 Trouble Starting
» Petter A1 starting (or not in my case)
» Petter A1 Starting Issues
