ECC generator
ECC generator
Many years ago, I found this right on top of the scrap metal skip at the Council Tip. It was just waiting for me, a gift! I think I gave the man £5, or maybe less. According to the brass label attached, it was made by the Enfield Cycle Company in 1943, with a WD serial number. It is a 4-stroke petrol, 50cc, driving an alternator with a huge plate rectifier to give an output of 20 volts DC. I believe it was made to be dropped in its own cage and probably a canvas cover by parachute behind the lines for charging radio batteries. The pulley was missing; The original was about 1" wide. The wiring was wrongly connected. The key-way on the shaft was worn, and I had to machine it and make a stepped key. The other major jobs were to cut a new exhaust valve seat, and the cam followers were missing. I made new ones from a high tensile bolt turned on the lathe. The original armoured HT cable sleeve and spark plug were discarded because they were shorting out. Spark is supplied by magneto. It usually starts on the fourth pull.
Bodgerac- Born to be wild
Re: ECC generator
Cracking little thing, lots of work to get it up and running again too, very rewarding taking something out a skip and getting it going.
Re: ECC generator
Its a shame it doesnt have its original frame that it sat in with a canvas cover, several companies made them during the war, it was designed by Edgar T Westbury, there is a youtube video here. https://www.youtube.com/watch?v=q_g6RiB0RVQ
Re: ECC generator
Nice unit and what a rectifier!
Alan
Alan
Re: ECC generator
Actually, one has just turned up on e-bay-uk, issue number 165135415546. It is very sad, unfortunately. I have taken a screen-shot, and maybe one day make a frame.
Re: ECC generator
Just watched the video, Maryalice, thank you. Excellent.
