Lucas SR1 magneto base/mounting plate
I have a Lucas SR1 magneto that is in very good condition and I would like to put it on my Lister D, trouble is there is no base/mounting plate on the bottom to mount on my D. Does anyone have one that I could have/buy please or I have many Lister D spares that we could do a swap if needed???
Re: Lucas SR1 magneto base/mounting plate
Try Andy Dry at Vintage Magnetos, Bristol; they hold much Lucas stock.
Eric
Eric
cranium- Expert
Thank you, will send a message!
I'm a little confused, to confirm my thoughts i've checked some pictures and the SR1 has the four threaded holes in its base.
Can you photograph your magneto.
In all the years I've played with Lister D's, I have five, I've never seen that before but mine are earlier ones.
Yes the SR1 mags have a lower shaft height than the earlier RS1's and different bolt hole centres so need a spacer plate, I had to fit one on my first D Type as the previous owners (a local quarry) had simply perched it on four pieces of screwed rod.
» Petter M type base plate
» Lucas SR1 magneto
» Lucas RS1 Magneto help
» magneto id
» Magneto Help Lucas N1
» Lucas SR1 magneto
» magneto id
