Fuel leaks
Fuel leaks
Morning all,
I've got a Villiers Mk12 which runs well and is in good condition. It's weeping from two places though - the seal between the fuel tap and the tank, and also the brass union which screws on to the fuel tap (plunger type fuel tap).
Can anyone tell me what the parts are I need to get to sort this? It looks like a fibre washer on the fuel tank, but not sure if this is correct? And the brass union - will that have an o-ring?
Cheers in advance!
APOLOGIES - I've put this in the wrong forum, if any mods can move it then I'd appreciate it. Sorry!
Cheers in advance!
MT500- Born to be wild
Re: Fuel leaks
No apology necessary - easily done.
Imperial fibre washers still obtainable online.
Also try:
https://www.lsengineers.co.uk/lister-petter-villiers-engine-spare-parts.html
https://www.gsparkplug.com/fuel-oil/copper-pipe-hose-connectors/1-4-bsp-general-fuel
https://www.ebay.co.uk/itm/202603899050?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338722076&customid=&toolid=10050
Also try:
Re: Fuel leaks
I take it the fitting that goes onto the tap is just a stub that the fuel hose pushes on to? IIRC that should just be a taper seal. It may be possible to lap it in with some metal polish.
Re: Fuel leaks
Cheers mattblack and woodsman. Good stuff to go on there and I'll let you know how I get on.
» Petrol tank leaks.
» How much fuel do you use?
» what fuel should I use?
» FUEL TAPS on a DK
» good on fuel?
» FUEL TAPS on a DK
» good on fuel?
