Bearings size
Bearings size
Hello.
Iv just ordered some bearings rls14 and rls12 so the problem I have is the sizing of one of the bearings.
Rls12 is right.
Rls 14 is right size apart from the width now someone correct me if I'm wrong but rls 14 lj1 .3/4 should be 20.64mm width but it's not got that it's saying 17.46mm here's the link.
Can someone tell me if this is just a mistake on there site or for some reason they are making a bearing the wrong size ?.
https://www.bearingboys.co.uk/Imperial-Ball-Bearings/LJ134-Imperial-Open-Ball-Bearing-RLS14-4445mm-x-9525mm-x-1746mm---5528-p
Ryan
Rls12 is right.
Ryan
Ryan90w- Expert
Re: Bearings size
Width should be 13/16" - is it now corrected on BB site?
nickh- Expert
Re: Bearings size
Yes I rang them and they have updated there website with the correct size.
Ryan90w- Expert
» First lister D, and first time everything else in old engines.
» Crank bearings
» Lister DK Remove Crank bearings/Shaft.
» Petter main bearings
» Adjustment conical crankshaft bearings Kubota
» Crank bearings
