Weak spark on JAP 2A
Weak spark on JAP 2A Empty Weak spark on JAP 2A
Post by Rookesy Mon Oct 24, 2022 2:48 pm
Gents,
I am restoring a JAP 2A and I'm getting a weak spark but not sure why.
When I turn over the engine with a drill I get a weak spark between the HT lead and the block but it has to be held very close. I have tried a variety of plugs and there is never a spark between the anode and the leg but if I get the plug close enough I get a spark between the block and the anode.
With a multimeter set at 20K ohms I get a reading of 3.86 between the coil stud and earth. There is a brand new condenser fitted. The points have been cleaned and are gapped at 0.015. Any suggestions as what to try next please?
Mick
Rookesy
Weak spark on JAP 2A Empty Re: Weak spark on JAP 2A
Post by Rookesy Tue Oct 25, 2022 2:49 pm
I was in the process of swooping back plates when I found a loose connection on one of the wires going to the condenser from the coil. It must have broken when I took the old one off. 5 minutes with the soldering iron and I have a cracking blue spark.
Mick
Rookesy
Post by Woodsman Tue Oct 25, 2022 4:09 pm
The simplest answers are the best. Nice work - crack on!
Post by mattblack Tue Oct 25, 2022 5:51 pm
Woodsman wrote:The simplest answers are the best. Nice work - crack on!
And the cheapest!
mattblack
mattblack
