lister junior
lister junior
Hi i have a lister junior when i go to start it up i get fuel coming from the bottom of carb where the brass slide sits on carb gasket can anyone give me advice on how to fix
thank you
thank you
frank- Born to be wild
Re: lister junior
From memory there should not be a gasket where the brass slide sits on the carb, I thought the slide ran metal to metal ?
Maybe maryalice will be along to advise if my memory needs to go to specsavers (or not).
Re: lister junior
Hi yes there is a gasket between carb and head but it just runs out if it does not fire straight away, and the brass slide fits into gasket and carb goes on top it must be flooding i am thinking
Re: lister junior
thanks for reply i think i have fixed problem now one other question does anybody know tappet clearance
for same engine 1926 lister A junior
thank you
thank you
Re: lister junior
Sadly I've been out of the loop this last week and only just picked this up, Blue Cat sorry to hear your memory need to go to specsavers. there should not be a gasket as suggested the slide runs metal to metal, if its leaking petrol chances are youve opened the fuel valve to much.
sadly, I've been ouut of the loop the last few day
Re: lister junior
hi can you replace LS1 magneto with one from a Lister d
thank you
thank you
Re: lister junior
Yes, just check rotation is correct, there are arrows on them to show you which way
Re: lister junior
sorry i mean SR1 magneto can i fit a Lister d mag?
thanks
thanks
Re: lister junior
Still yes, just check the threaded hole pattern in the base of both mags.
