Deutz MAH711
Deutz MAH711
Hello. I have a deutz Mah711 stationary engine I'm restoring. The previous owner obviously " tinkered" with the injector. I am trying to set it up but need to know the pressure it should be set to open. I have a copy of the manual...but it just says measure the screw top to locknut distance before disassembly. ...not much use if somebody's been there before!!
Many thanks
Ribbo
Many thanks
Ribbo
ribbo- Born to be wild
Re: Deutz MAH711
You need to identify the injector nozzle to know its operating pressure, depending on the type of nozzle you will need a pressure gauge that measures in hundreds of PSI maybe thousands and I assume you don't know if the pump is delivering the correct pressure. You'd be better off taking the pump and injector to a service centre to get it checked over.
One other point, do not wipe the nozzle with your fingers, the nozzle spray will easily burst your skin and inject you with diesel which will mean a trip to the hospital.
Re: Deutz MAH711
Thanks for that. I'll post number of nozzle when I take injector out again.
Re: Deutz MAH711
Whats your German like, there is a Forum https://www.deutzforum.de/whats-new/posts/465444/
Re: Deutz MAH711
Many thanks. The engine is my son's....and he's sent video of it running just now. He's been working on it allmorning. ..adjusted pump...injector and governor by "eye!" He is an agricultural engineer....but at least its now running .
» Deutz mah 711 age?
» Deutz mah 711 belt driving query
» Deutz MAG SA diesel poor starter F1L 210D
» Deutz 1904 hot tube
» Deutz info needed
» Deutz info needed
