Head gasket for D420
Bodgerac- Born to be wild
Re: Head gasket for D420
What makes you suspect the head gasket?
However, you could maybe make your own from annealed copper or aluminium sheet - or have a look at BGA RPK1 Gasket Material.
The gasket is a stamped stainless steel with a groove around the outer edge in the stamping. Very thin. When running, a fine mist blows out from between the cooling fins. It does not smoke, so the rings are OK. Next stage is to check the valves.
» head gasket
» Ruston Hornsby AP head gasket
» a bit of a swap.
» JAP 2A Cylinder head gasket
» BSA 420cc head gasket
» a bit of a swap.
