Petter a11 cylinder head
Could someone help me please? I have a petter a11 and had to remove the valves because of low compression. They came out easy enough but I can’t get them back in. Do I need specialist tools?
Meloncholia- I really need to post more
Re: Petter a11 cylinder head
I've had plenty of success with these: https://www.ebay.co.uk/itm/176297958035
Other similar compressors are available. What diameter are the springs?
I will look at this on eBay and thank you for your help.
You're welcome.
If you give us the diameter of the springs I can check that they will fit in B&S tool
Help, where can I get replacement parts?
I’ve been working on our Petter a11 and found that we need a replacement piston ring. Does anyone know where I can find one? Many thanks to you all, Martin and Paul.
Size (diam + thickness + width ) would be useful
Maybe try: Stationary Engine Parts, FW Thornton, Cox & Turner ?
Hello thanks for your help I will try to get the information for the piston rings. Also will have a look at where you recommend. Thanks again, Martin and Paul.
» Petter W1H refurb (1950)
» cylinder head
» Cylinder head temperature?
» Lister 6/1 CS cylinder head
» Cylinder head Torque setting liste Dr
» cylinder head
