Cylinder head Torque setting liste Dr
What are the torque settings for the lister D cylinder head also the copper gasket should it greased or dry assembled?
Shane.N- Born to be wild
Re: Cylinder head Torque setting liste Dr
There are no actual torque settings, I grease lightly my head gasket and then tighten all of the bolts down by feel, fill with water and start the engine and watch for bubbles, nip the nuts until the bubbles stop, after its been run for a while and warmed through nip them all again.
Mary Alice
Mary Alice
Thank you Mary Alice. I am nervous of strippin the Brass Nuts.
I've never stripped a head nut and I'm a Gorilla when it comes to tightening up nuts and bolts.
Make sure the threads are clean and the nuts screw on freely.
[quote="maryalice"]I've never stripped a head nut and I'm a Gorilla when it comes to tightening up nuts and bolts.
Maryalice[/quote]
Also make sure you are doing the nuts up tight and not bottoming out on the thread as the washers are missing...
Maryalice[/quote]
Just finished putting the head back on New washers from Stationary engines needed reaming out to the correct size Metric equivalents are not good enough!!!!!! School boy error assembled the rocker shaft and then discovered couldn't get the head nuts on!!!! big learning curve thanks for all the help
https://drive.google.com/open?id=1s3Rqs7nYTF0D5I_yB6zEgaEW2n6nmLWZ
Pleased its gone well, Villiers, thanks for remembering the washers I completely forgot about them.
I put a little dab of grease both sides of the washers they tighten down easier
» Enfield HO2-MK4 TD/5155 cylinder head bolt torque?
» JAP Model 2 A head bolt torque settings
» Petter a11 cylinder head
» Lister 6/1 CS cylinder head
» Petter W1H refurb (1950)
