Villiers Midget mk2
Villiers Midget mk2
I have started to disassemble a Villiers Midget Mk2 engine and am having difficulty with removing the flywheel. I can unscrew the nut a few turns but then it binds up and won't budge further. When loosened I can't turn the flywheel without the drive shaft turning. It is like the flywheel is seized on the drive shaft.
Any ideas much appreciated.
Also, what is the best way to remove rust stains from carburettors to end up with a nice finish?
Greg
Greg
bluedog- Born to be wild
Re: Villiers Midget mk2
Greg the flywheel is 'self extracting' on Villiers. The nut has gone loose and then tightened again, now you need to put a spanner on it and clout it with a hammer, the nut will then go loose again and if you keep turning it will draw the flywheel off, simple!
Thanks Pete. It took a few wacks but then it came off.
» Villiers midget Mk3
» Villiers Midget only runs for a few seconds..
» Villiers midget modification
» Villiers Midget Gudgeon Pin
» villiers midget 2 stroke
