1938 petter a.
1938 petter a.
this 1938 petter a found its way into my shed when i was out.
it is a runner but i will restore it over the winter along with my a1.
Earl.
earlsinclare- Life Member
Re: 1938 petter a.
Nice looking engine there,
The flywheel are easier to remove from these engines compaired to the a1.
Ive never been able to remove an a1 flywheel without damaging the thing, but the a type engine seem to come of no probs with a bit of patiance.
I have one of these engines there nice engines.
What is the depth of you sump?
As the a type engine had 2 diffrent size sumps.
Re: 1938 petter a.
its the model with the shorter sump.
Re: 1938 petter a.
Thats you sorted for the winter
Re: 1938 petter a.
i don't know...the nerve of some people....
cant even go out with out some one leaving things in your shed....
well done...please keep us posted with the progress....
many thanks....mike....
in bits looking for the noise.
i think i have found the noise, the starting cog on the inside is worn around the shaft, anyone got any ideas on the best way to fix it.
Earl.
Re: 1938 petter a.
HI EARL...
Steve is your best bet..(skankin giant)....
its his field of expertees....
good luck...
good luck...
noisy gears.
i found the noise, it was the fixed shaft that the starting gog/gear sits on this has now been repaired ( i knew the lathe would get to do a serious job eventualy). all i need now is a better set of timing gears the set on the engine are very worn and chattery. i've put an add in SE so we will have to wait and see.
Earl.
Earl.
Re: 1938 petter a.
mike d wrote:HI EARL...
good luck...
I have a field of expertise? its news to me , I know abit about Normans, and Stuart Turners but thats about it,
Communications is what im trained in everything from Computers to Radar and sat comms, havnt done any machine work since I sold my Mini lathe.
Re: 1938 petter a.
HI EARL...
looks like you've been busy..glad you found the problem....
theres nothing worse when you cant find the problem....
well done.....
regards.....mike...
well done.....
regards.....mike...
» 1938 Lister D Reverse rotation
» Benco vacuumpump overhauling update 03072015 dating the pump. Yes it's very old!
» 1938 Lister 23D2H pump set
» petter A arrives home whilst wife out
