unknow pump
unknow pump
got this little brass pump.i dont know who made it.but its nice.
thinking of puting it to run with my stuart turner engine.
Diddy- Life Member
Re: unknow pump
Dave what is the part from the tap outwards about ....? i cant seem to figure out what it would do .... as i can see its a centrifugal impeller pump with inlet and outlet either side of body . but thats it . pretty basic to be honest .
Re: unknow pump
that bit on the end was a large bullet head.that got milled out then drilled to take the bit of pipe.i stuck in on a 5hp petter at 2000rpm i got bloody soked.
Diddy- Life Member
Re: unknow pump
i thought maybe it was for priming?
hob- Life Member
Re: unknow pump
i agree it looks like you fill with water though it then turn the tap of and then run the pump
pre wetted to start the suction off
like on my large centrifugal pump i run with MY LISTER A
Re: unknow pump
hob wrote:i thought maybe it was for priming?
thats quite plausible ... i thought it might be a drain but not with the cup part on it .
Re: unknow pump
thats wot i did with that end used it for primeing.
Diddy- Life Member
Re: unknow pump
so its best used with pipes fitted then that are facing away from you then dave lol
sounds like its got good output flow then ???
sounds like it will get rid of unwanted pets and children then from a distance lol
Re: unknow pump
Very nice looking pump shame about the alloy pulley, that will shine up nice for the rally field.
Re: unknow pump
Ooooh, look at all that brass. I could spend hours with my Dremmel polisher on that.......
DanBoy- Life Member
Re: unknow pump
a up dans got a fetish..lol.is wot it could do with is rubbing down to take all the pitting out the body make it smooth.well im not going to use it now as iv got another idea for st engine.it will be all on a very little trollyhidden water tank think the fuel tank mite be hidden as well apart from the fuel cap.
Diddy- Life Member
Re: unknow pump
forward thinking on the trolley design and going for a steamline finish
i like it mate sounds a good idea to me
cant wait for the photos to start rolling in of the stuart pumping set up trolley
good look
good look
» 1938 Lister 23D2H pump set
» Pump ID please
» Found Something For The Amanco To Run
» Can anyone tell me what pump this is please
» Warsop pump
» Pump ID please
» Warsop pump
