Warsop pump
Warsop pump
Well, you know how it goes... I wasn't looking for a another project but this was on ebay starting at £22 and wasn't to far away. So I took pity on it and decided if there were no other bids...
Villiers MK12 engine, turns over but no spark according to the seller. If anyone has any literature or info on Warsop pumps I would be interested.
Re: Warsop pump
I did up one just like that a few years ago the bolts holding the pump down will be very corroed and I found the bottom of my pump had rotted out!
Apart from that it was a nice little project good size to keep too.
John clare- I really need to post more
Re: Warsop pump
To unscrew the impeller turn it the same way as the engine rotates as it/s the weight of the water that keeps it tight good luck
Re: Warsop pump
I saw that, glad you got it for a good price. Sadly I couldn't shift the impeller on mine without breaking it and it had some other issues so it ended up as spares. I don't suppose you want a spare pump housing and base, do you?
Re: Warsop pump
So is the impeller threaded onto the end of the engine crankshaft?
Re: Warsop pump
Robotstar5 wrote:So is the impeller threaded onto the end of the engine crankshaft?
I believe so... I've still got the block with the crank in with the remains of the impeller on. You're welcome to it if you want to do a dummy run before tackling yours.
Re: Warsop pump
Thanks for the offer, but it's going to be a while before I look at the Warsop as it was one of those "right price, right place" buys and there's 3 projects in pro at the moment, just have to wait for spring as no heating in the workshop
Re: Warsop pump
Robotstar5 wrote:Thanks for the offer, but it's going to be a while before I look at the Warsop as it was one of those "right price, right place" buys and there's 3 projects in pro at the moment, just have to wait for spring as no heating in the workshop
No problem, I may try to cut the remains of the impeller off anyway when I get a minute just out of curiosity to see how it is attached.
» Warsop s6 breaker
» Warsop road breaker
» WARSOP BENJO POWER RAMMER - for sale - WORKIMG
» Warsop Benjo rammer, jumping Jack, paddy's motorbike
» Pump ID please
» Pump ID please
