need some info on a 3hp sunshine engine,made in Australia
Page 1 of 2
Page 1 of 2 • 1, 2
hi all..
im after some info on the sunshine engine,its made in Australia thats about all i know..
can anyone help???????
many thanks..mike...
Re: need some info on a 3hp sunshine engine,made in Australia
Mike PM Triumphline, I'm sure I can remember seeing pics of the Sunshine on his old posts, if anyone can help you it will be him.
hi Stu..Patrick is on it as we speak mate...
waiting for him to get back to me...
regards,mike..
regards,mike..
Now why do you want Sunshine engine info. That's the question I'd like the answer too you got something up your sleeve no doubt.
no mate,i cant get a snot rag up my sleeve,let alone anything else....
my friend want some info...
i will post some pics tomorrow when hes sent me them...
now you know why i needed some info on the sunshine engine...lol.lol..
Yup already guessed it mate
yes mate..didn't want to say to much till deal was done...
Patrick (triumph line) is one the case,hes got a mate who has a shed full of sunshine engines.....
Great looking engine, do you know it's history and how it got to this country?
yes Stu..
it was brought over here by the feller i bought it from (mike Edwards)
its apparently a 1919 and he got it from fremantle in Australia...
hes always over there as he has friends who went over there back in the 70s on the £10 trip they did years ago..
so it was easier for him to bring it in personally....
Must have cost a few bob to ship but well worth it. Is there any more in the UK do you know?
sorry mate don't know..would be nice to know though..
mike d wrote:hi all..
Hi Mike,
what do you want to know?, common in Aus, nice collectors engines,
can run a bit rough without load, 2 stroke, hit & miss governing, made in 3,
5,7 and 10hp, the bigger ones are harder to find, cheers,
Chester.
OLDENGINES- I really need to post more
hi Chester...
thanks for the info..its a 3hp and ive been told its a 1919,but im waiting for Patrick (triumph line) to speak to his friend who has a barn full of them....
what i needed to know is do i need to use all 3 oilers at the same time,as ive seen them in Australia and they only seem to have one oiler open at any one time?????
ive found some manuals on a site that Patrick gave me,ive ordered them and they should be here sometime next week,so that mite help a lot as well...also whats the mixture ratio for the fuel...two stroke to petrol??????????
any info will be much appreciated...
regards,mike..
regards,mike..
Hi Mike,
the 3hps are a nice little engine, the 2 outer oilers oil the main bearings,
these are a bronze taper bearing and seal the crankcase so it is important
to have them lubricated. The oiler in the middle is what controls the oil/fuel ratio,
(you run straight petrol in the fuel tank, the oil is mixed in the crancase)
i run 2 stroke oil in it, it is a bit hit n miss to get it set right, i usually start with a
high drip rate and then back it off untill there is little oil comming out the exhaust.
I did try running mine on 25-1 2 stroke mix with the oiler turned off, but it was way to rich, i may try a 50-1 mix and see what happens, my 5hp needs to be primed really well to start it, about 5 of the priming cup fulls, also fill the carbie up through the
filler. Cheers for now,
Chester.
Chester.
That sounds like some good advice you've been given there Mike.
We need to see a video of it running.
OLDENGINES wrote:Hi Mike,
(you run straight petrol in the fuel tank, the oil is mixed in the crankcase)
high drip rate and then back it off until there is little oil coming out the exhaust.
I did try running mine on 25-1 2 stroke mix with the oiler turned off, but it was way to rich, i may try a 50-1 mix and see what happens, my 5hp needs to be primed really well to start it, about 5 of the priming cup fulls, also fill the carb up through the
Chester.
hi Chester....
many thanks for the information,will give it a go and see how it goes...
is your engine the same size as mine,or is it a bigger one.....
kind regards.mike....
mike d wrote: is yours the same size as mine,or is it a bigger one.....
Bit personal Mike
stationary stu wrote:That sounds like some good advice you've been given there Mike.
yes mate,that's what i thought..nice to get some info when you need it..not like some forums...
and its very much appreciated indeed..
mike....
will try and sort a video out of it running,but its a bit technical for me but will try...
mike....
Get Ian to show you how to video, he has a bit of common sense
yes i mite do that,but im going to have a go myself first...ive got a bit of common sense....
mike d wrote:yes i mite do that,but im going to have a go myself first...ive got a bit of common sense....
Ok if you say so
stationary stu wrote:mike d wrote:yes i mite do that,but im going to have a go myself first...ive got a bit of common sense....
OK if you say so
well i didn't say i could do it,but if i don't have a try i will never know..that's what i say to the MRS anyway..lol.lol...
You a typical guy then Mike, have a go then read the instructions, still can't understand it so say sod it I'll wait till the kids come round.
Page 1 of 2 • 1, 2
» Hamworthy Air Compressor info for Newbie from Australia
» need to find info on engine iv inherited from my Dad
» Lister D engine date and info please
» Crossley engine info
» BSA engine number info
Page 1 of 2
