BSA engine number info
BSA engine number info Empty BSA engine number info
Post by pyronaught Tue Jul 06 2021, 11:13
Hi all,
I have a BSA engine, which I believe to be a 420cc (From the length of the exhaust flame trap). I have a pdf of the original manua for the 320 and 420cc versions - which seems to indicate the engine numbers would begin with 'A' or 'E'........but mine appears to be: G 22283/PL/AS! There is also an 'HS' stamped above this on the casing.
Any ideas as to whether this confirms or denies the engine size?!
I've managed to re-establish a spark from the magneto - now need to check the carb and then see if it will fire up!!
TIA! Dave.
pyronaught
BSA engine number info Empty Photos of BSA 420cc(?)
Post by pyronaught Tue Jul 06 2021, 11:31
pyronaught
BSA engine number info Empty Re: BSA engine number info
Post by Robotstar5 Tue Jul 06 2021, 11:39
Not sure about the G, but Villiers tend tend to use HS to denote a High Speed engine which runs a bit faster than a standard engine to give a higher power output.
Before working on the carb just put a few drops of fuel down the plug hole and give it a pull to see if it fires Thumbs Up
Robotstar5
Robotstar5
Post by pyronaught Tue Jul 06 2021, 12:41
Thanks Stuart - interesting!
It was sold as a 320cc engine - but it seems to be potentially getting bigger/more potent all the time!!
Will give your suggestion a shot re firing!
Dave.
pyronaught
Post by blue cat Tue Jul 06 2021, 20:01
BSA 420cc HS (high speed) model. G = 5.75hp @ 3000 rpm
Lucky to have the original exhaust silencer.
Post by pyronaught Tue Jul 06 2021, 21:14
Brilliant - thanks Blue cat!
Smile
pyronaught
Post by Woodsman Wed Jul 07 2021, 09:29
Hi Dave.
I have manual for 320/420. PM me if you would like a copy.
