Lister D Type
Lister D Type
I've just bought a Lister D S/N 197507 Type 28 DH
Can anyone tell me from this information if it is a clockwise or anti-clockwise rotation.
Unfortunately it doesn't have a carb so I cannot see which port it should go on.
Thanks
Martin
Thanks
Martin
pettyofficer- I really need to post more
Re: Lister D Type
pettyofficer wrote:I've just bought a Lister D S/N 197507 Type 28 DH
Thanks
Martin
look at the starter dog and see which way it catches and would turn . and go from there .
Re: Lister D Type
matt86 wrote:pettyofficer wrote:I've just bought a Lister D S/N 197507 Type 28 DH
Thanks
Martin
your on the ball feller...lol..lol
did you want any of the amp meters ?????????
Re: Lister D Type
If it is just marked up as a DH then it should be standard rotation. Reverse engines were usually marked as DHR or sometimes DHZ.
Re: Lister D Type
clockwise rotation carb goes on the left port as viewed from the ports...A big clue is also look at the governor arm and see which port it also lines up against...
jay- A credit to the forum
Re: Lister D Type
mike d wrote:matt86 wrote:pettyofficer wrote:I've just bought a Lister D S/N 197507 Type 28 DH
Thanks
Martin
It's not a reverse rotation, I put a starting handle from a running engine and it engaged straight away. Thanks for the help, I now don't need to go looking for the special carb and bits.
Martin
Re: Lister D Type
The carb on rev rotation isnt a special one.. its a normal carb but the throttle spindle has a pin which is knocked out and turned round so its on the opposite side simlar to governor is adjustable as you do both on parrafin engines..
There was a few D type carbs on ebay or post a wanted ad as someone may have one..
Re: Lister D Type
I've now started on work on one of the engines, the brass water tap is missing. I know that has a 1/4 BSP on it but the insert is also missing. It has a rusty piece of thread in it instead, anybody got one of these inserts or could tell me what the outer thread is. It's Part 236 in the lister parts catalogue.
Thanks Martin
Thanks Martin
