weight of a lister d
hi was wondering if anybody knew the weight of a lister d sheep shearing engine
brooko- Born to be wild
Re: weight of a lister d
From the engine I've got I think it's around 135kg, not sure what that is in pounds but that is only the engine. In shorts very heavy!
James
James
bradders- Expert
mm5aho- Expert
0.45kg to a lb :xxx1:stationary stu wrote:A rough guide double kg = lbs
when did that smiley get added!!! I like it
blackvanman- Life Member
I read somewher that they weigh 300 lbs. In new money that's 135kg. Dan.
Hagman187- Born to be wild
blackvanman wrote:0.45kg to a lb :xxx1:stationary stu wrote:A rough guide double kg = lbs
Careful Andy don't want to set your heart racing. :stick lol: :stick lol: :stick lol: If you ask nice I might add another :chin:
That's it Dan, not very light weight
» Climax no.(not established) belt driven piston pump strip and refurbish blog.
» Weight of Ruston 6ap
» Petter Junior weight?
