LISTER A FUEL PUMP SPRING
Does anybody know if the spring inside a Lister A fuel pump is the same as the one found on a Lister CS?
My spring has broken on my fuel pump on my Lister A, but I can only find a replacement for a Fuel pump for a CS on Stationary engine parts.
Cheers,
Cheers,
BRASSO- Life Member
Re: LISTER A FUEL PUMP SPRING
not a clue , cant you just match the spring up to another try going to a engineer suppliers who sells bearings seals etc , they should be able to match it ...after all its only a return spring .
The A spring is a lot smaller I think.
» Lister L fuel/oil pump
» Lister Junior - re-packing fuel pump
» Lister Junior fuel pump pipe fitting to Carb
» Lister D air valve spring lock-nut
» Lister D fuel
» Lister D fuel
