LISTER A FUEL PUMP SPRING
LISTER A FUEL PUMP SPRING Empty LISTER A FUEL PUMP SPRING
Post by BRASSO Sun Aug 11 2013, 23:34
Does anybody know if the spring inside a Lister A fuel pump is the same as the one found on a Lister CS?
My spring has broken on my fuel pump on my Lister A, but I can only find a replacement for a Fuel pump for a CS on Stationary engine parts.
Cheers,
Very Happy
LISTER A FUEL PUMP SPRING Empty Re: LISTER A FUEL PUMP SPRING
Post by matt86 Mon Aug 12 2013, 07:55
not a clue , cant you just match the spring up to another try going to a engineer suppliers who sells bearings seals etc , they should be able to match it ...after all its only a return spring .
Post by Appletop Mon Aug 12 2013, 08:05
The A spring is a lot smaller I think.
