Metal spraying.
Metal spraying.
Hi all.
Does anyone know of a cheap place that does metal spraying?
If all goes to plan there will be another engine in my Shed next Saturday, its been restored but has run the main bearings and will need the crank skimming then building up, or so i'm led to believe! but until i get it home and look inside i cannot be sure!
i won't say what the engine is just yet but i may be asking around for another crankshaft instead. watch this space !
__________________
__________________
100ish Allens,1xListerH, 7xListerD's,3xListerA's,2xListerB's,1xListerJ,1ListerLH,2xListerM's,1xListerN, 1xwolseleyWD11,1xWolsleyWD8,1xRuston1.5PB 1xRustonPB3hp,1xRustonPT, 1xLister CS9/1, 1xAmanco3-1/2hp.
Re: Metal spraying.
is it british?, horizontal or vertical. (but then seeing pics of your collection is most likely a Lister!!!)
Re: Metal spraying.
It's a type that I've not got, its hopper cooled and vertical !Lewis MacRae wrote:is it british?, horizontal or vertical. (but then seeing pics of your collection is most likely a Lister!!!)
And Brittish !
Re: Metal spraying.
Well it's followed me home today, just after a blowout on the trailer!
here is a first piccie;
Re: Metal spraying.
petter m appletop 3 hp ?
Re: Metal spraying.
Re: Metal spraying.
thats was a good guess then
looks quite good condition , you soon have her running and spitting oil over your roof !
Re: Metal spraying.
Looks great does it run?
Re: Metal spraying.
Is there a flywheel missing?
Re: Metal spraying.
No. That side was stil dismantled when I brought it home and was in the boot of my car !Lewis MacRae wrote:Is there a flywheel missing?
Re: Metal spraying.
It's capable of running but has an issue with binding up in the bore and is now stripped for the liner to be skimmed and rings to be gapped !Lewis MacRae wrote:Looks great does it run?
Re: Metal spraying.
Hi all, after another evening working on the Petter , i had got to the point where i going to refit the piston rings onto the piston and all was going well until i got to the last one and you guessed it ,crack ! i broke the damn thing, So my question to you is; does anybody have a spare 3-3/4'' ring to fit a 3hp M ? if not where is the best place to obtain one please?
Off to a dark corner to sulk now ! ,Karl.
» metal in the size you want.
» Mallard Metal Packs
» Red oxide metal primer
» 1st time metal solderer ...
» Lister D White metal Big End bearing
